02-05-2019
05:58
11:22
02-05-2019
05:58
11:22
There are two lines across the top of the screen on my Fitbit Charge 3. I rebooted the device, but that didn't fix the problem. I've only had it for two weeks.
02-06-2019
05:02
10:52
02-06-2019
05:02
10:52
A warm welcome to the Community @tshelto8.
I appreciate all the efforts in trying to fix this display issue by yourself. Please perform a long restart by doing the following:
Let me know the outcome. ![]()
02-06-2019
05:02
10:52
02-06-2019
05:02
10:52
02-06-2019 19:54
02-06-2019 19:54
I tried what you recommended and the problem still exists.
02-09-2019 10:20
02-09-2019 10:20
03-13-2019 07:50
03-13-2019 07:50
I have a similar issue. I have only had the device since December/January and just yesterday the screen stopped displaying properly. I have tried all of the reboot suggestions and the suggested solution displayed here.
How do I get a replacement device?
03-17-2019 20:31
03-17-2019 20:31
Hi, I am having issues with several blank lines going across the top of my Charge 3 display. I tried the restart that you suggested several times and it still the same. I have only had it since January, and it is very disappointing since it cost quite a bit. Please, advise. Thank you, in advance.
05-02-2019
05:38
04:21
AlejandraFitbit
05-02-2019
05:38
04:21
AlejandraFitbit
I also have the two or three blank lines across the top of the display. I tried the fix and it didn't resolve itself. The smiley face comes up before I get to the finish of the 15 seconds. Can I do anything else?
The solution didn't work for me...I tried twice. I've seen several people who have received replacements, how do I get a replacement as well?
Thanks,
Moderator edit: content
Best Answer05-06-2019 09:27
05-06-2019 09:27
Best Answer05-06-2019 09:29 - edited 05-06-2019 09:31
I purchased it last Fall (10/5) so it isn't even a year old.
05-06-2019 09:39
05-06-2019 09:39
YES.. like new but it took several tries. Life is good....
Best Answer05-06-2019 10:00
05-06-2019 10:00
A replacement is on the way. The online chat agent was very helpful. We tried the fix once more with the same result, and since it was still under warranty a replacement will be coming.
05-06-2019 10:13
05-06-2019 10:13
This reset suggestion didn’t work for me. Stripes are still there and starting about an hour ago, as I posted in another thread, the screen is flashing from the main screen to the wake and vibrating each time it flashes. I took it off because the vibrating was so annoying and now the screen is black and the fitbit won’t wake up at all.
05-06-2019 11:26
05-06-2019 11:26
How frustrating! I suggest you get on the help chat and get someone to work through this with you. I had a screen problem a few weeks ago where it wouldn't respond to taps or swipes...it was frozen. A reboot fixed it, maybe you could try that.
But the fix for the lines didn't work for me at all. A help agent worked with me and determined it needed to be replaced and since it was still in warranty, there is no cost to me.
Good Luck
04:27
09:59
05-08-2019
04:27
09:59
Hey guys, I hope you are doing fine.
I am sorry for the delay in respond and to hear about your frustration. Thanks for troubleshooting this display issue.
@Cbswint, @brucefit89 and @KCDChrge3, those are great news, I am glad to hear that you received replacements or that your trackers are now working. If there is anything else we can help you with, do not hesitate to post it.
@Pene2017, upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
I will see you around. ![]()
Best Answer05-13-2019 08:48
05-13-2019 08:48
Hi there, I got the same problem a few weeks ago (lines on the display), and it's gotten to the point where the display is pretty much unreadable. I've tried the smiley face reset multiple times, but I can't seem to get the blank screen reset. I got this Fitbit as a gift around Christmas time (probably slightly before), but I don't have a receipt. Help please!
05-14-2019
07:02
14:03
05-14-2019
07:02
14:03
Welcome to the Forums @Fattydigits.
Thanks for troubleshooting this screen issue. Since the steps provided in this thread didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted. ![]()
Best Answer05-14-2019 08:15
05-14-2019 08:15
Best Answer07-04-2019 03:54
07-04-2019 03:54
Same here....
Best Answer07-11-2019 06:38 - edited 07-11-2019 10:19
No luck with the multiple tries to fix the non-display. I am a fitbit fan. Many people have "display" problems. I am wondering if this is an admitted software/hardware/quality issue by fitbit has fitbit corrected before I push for a replacement. We purchased in February 2019, about the time this and other chats started. Thanks.
Best Answer07-11-2019 07:01
07-11-2019 07:01
I have the 3 lines on top of the display and just tried the plug in-hold side button-unplug- plug in.... no smiley face and still lines...????
