02-05-2019 05:58 - last edited on 11-17-2020 11:22 by MatthewFitbit
There are two lines across the top of the screen on my Fitbit Charge 3. I rebooted the device, but that didn't fix the problem. I've only had it for two weeks.
07-11-2019 07:05
07-11-2019 07:05
How did u fix it??
07-11-2019 07:58
07-11-2019 07:58
I ended up chatting with Fitbit support. They had me try the fix while we connected and after it didn't work out they sent me a replacement.
07-11-2019 17:45
07-11-2019 17:45
08-04-2019 08:06
08-04-2019 08:06
Good morning! I too am having this issue with my Fitbit display missing lines. I tried the suggested reset several times with no change to the display. I've only had it since February.
Please help!
08-04-2019 11:52
08-04-2019 11:52
08-09-2019 09:10
08-09-2019 09:10
Mine is not working anymore either. The functions are recording but no display. Tried the long reset and did not work at all. None of the solutions I have read here seem to work.
Jean
08-09-2019 09:19
08-09-2019 09:19
09-05-2019 15:39
09-05-2019 15:39
Mine has lines across, tried solution many times - rubbish for such an expensive piece of technology! I wish I’d listened and gone with apple now 🙁🙁
09-05-2019 18:11
09-05-2019 18:11
11-12-2019 11:41
11-12-2019 11:41
I have a replacement Charge 3 after this happened to me once and now it's happening again. The replacement was a used unit (there were messages to someone else stored on it). I've tried the hard reset four days in a row to no avail. Now what?
02-16-2020 16:50
02-16-2020 16:50
Sad to report that my 2 month old Charge 3 has the same problem. Display control software could be. corrupted but there is a better chance that the display LCD's or the driver is failing. Quality control is a must and high failure rates result when this step is skipped.
02-22-2020 14:43
02-22-2020 14:43
Does not work
02-26-2020 09:07
02-26-2020 09:07
I have had the Charge 3 for a little over 1 month. Now the bottom half of the touchscreen does not work. you cannot scroll upwards and on the menu screens you can not choose the bottom icons (i.e. relax, alarms). With a full charge, I have tried all of the suggestions online, including resetting by holding the side button for 15 seconds while plugged into the charger. Any other suggestions?
04-29-2020 15:54
04-29-2020 15:54
Didn't work.
04-29-2020 15:55
04-29-2020 15:55
Contact Customer service. It should still be under warranty.
04-30-2020 04:20
04-30-2020 04:20
I received my replacement Charge 3 in July 2019. By the beginning of this year (8-9 months later) the problem began again. The fixes did not work, and when I contacted customer support, I was told that the policy is to go by the warranty date of the initial purchase, therefore I did not qualify for a second replacement. They did offer a 30% discount on purchase of a new Fitbit device. I now sport a Garmin Vivosmart 4.
Fitbit needs to improve their quality control!
05-11-2020 19:53
05-11-2020 19:53
Hi, my charge 3 screen is corrupted as well just now, I've tried the suggested solution several times, but didn't work. Are there any other solution? Please help
05-25-2020 13:07
05-25-2020 13:07
I feel the same way as you.... the display on my screen doesn't work property but also swiping the screen from to the left or whatever doesn't work either. I Have the Charger 3 ,, Was thinking of going for the Charger 4 but now I'm thinking of trying Garmin or something. .
08-12-2020 17:31
08-12-2020 17:31
Earlier today I noticed my Charge 3 face was corrupted; displaying an unidentified pixilated picture. I saw some advice to charge it and hold down the button. I did that and the screen is now black, no matter what I do.
09-15-2020 20:05
09-15-2020 20:05
This just started happening to me as well after completing the new update. My watch is about a month out of warranty, so not eligible for replacement. It sux as this issue seems to be widespread and more of a product defect.
Has anyone come accross any solutions that might work to reset the screen?
