01-23-2019 06:16 - last edited on 11-17-2020 13:05 by MatthewFitbit
Fitbit Charge 3 display not working, why? It was at 95 % charge
03-15-2020 15:21
03-15-2020 15:21
I am thinking the same thing. I love having the tracker, but I have had 4 fitbits that became unusable. Fitbit is a very faulty product!!!
03-15-2020 15:23
03-15-2020 15:23
No the issue has not been resolved.
03-15-2020 15:24
03-15-2020 15:30
03-15-2020 15:30
I am in the same situation!! Very frustrating!
03-15-2020 15:33
03-15-2020 15:33
My warranty has also expired. Very disappointed because this is obviously a common issue they have and are aware of.
03-15-2020 15:35
03-15-2020 15:35
I also let the battery die since the fitbit won't restart. It did not fix the display though. I plan on buying another brand because fitbit is expensive and all 4 of mine in the past became unusable.
03-15-2020 15:38
03-15-2020 15:38
Omg they are awful.
03-15-2020 15:39
03-15-2020 15:39
They are still broken.
03-17-2020 13:35
03-17-2020 13:35
03-20-2020 01:26 - last edited on 09-06-2020 19:14 by LiliyaFitbit
FINALLY, I can say I know what the problem was with Charge 3.
Fitbit touts the Charge 3 as "*Water resistant up to 50M, so you can wear
your tracker or smartwatch in the shower, pool and beyond*." This should
mostly be true EXCEPT for the fact that the sealant that was used to
between the display and the body might have been substandard for this
feature.
First, I must declare that Fitbit Support team graciously gave me a small
discount offer towards buying a Versa to replace my Charge 3. I bought the
Versa exactly a month ago. I had to get it shipped to a friend in the US,
then subsequently to Kenya, where I live. I received it 2 days ago and as I
write this message, I have been on Versa 2 for the last two days. What a
beauty it is!!
A BIG THANK YOU to Fitbit Support Team. Now I just have to insure it in
case something happens.
So my Charge 3 has become redundant!
Together with my Electronics engineer friend, we decided to open up my
Charge 3 and check. We first watched a video on how some folks replaced the
battery on a charge 2 - the video can be found online. The first process in
that was using a hot air gun on the Charge 2 to enable one to easily pry
the screen to be from the body.
We had all the tools, but guess what? It wasn't even necessary to use the
hot air gun on the Charge 3. My friend just opened up the screen using his
nails!!!
We found out the following:
1. Moisture had accumulated on both ends of the ribbon that connects the
screen to the body.
2. It was pretty easy to clean up the end that is attached to the body as
it was easy to detach.
3. It was not possible to clean up the end of this ribbon that is attached
to the screen as there is no way to detach it
4. It is this corrosion caused by the seeping of moisture into the Charge 3
that we believe is causing the problem with displays - the ones that are
deteriorating, with white lines.
I don't know how to swim and I have never gone into the shower with my
Charge 3, so if anything, the only time it could come into contact with
water is if I walked in the rain or water splashed while I am washing my
hands. Given the water resistance specification, the only conclusion my
Engineer friend could come to was:
"It appears that Fitbit used a weak sealant in the manufacturing of the
Charge 3. The sealant is some light double-sided tape/adhesive. It's not
clear what the life of this sealant is, especially in the countries where
ambient temperatures are constantly on the high. It would appear that it
deteriorates, thereby allowing moisture into the device, affecting the
connecting ribbon. This might not hold true for all the Charge 3s, but it's
possible that there was a batch that suffered this unfortunate problem"
We sealed back the screen on my Charge 3 using the T-7000 sealant. My
engineer friend has used either T-7000 or B-7000 sealant on several devices
- GPSes from Garmin, Watches from Garmin, mobile phones, etc which he
repairs in his workshop.
My Charge 3 display at the moment is for all intents and purposes
invisible, I could see an outline of the battery when I connect it to a
charger though. Besides all that it was still able to sync with the app.
Now that I am not actively using it, and knowing that there is no easy
remedy, I am lost on what to do with it.
Does anyone know if Fitbit can sell me a replacement screen (complete with
the ribbon)? Or if there are 3rd party vendors for the same? I'd love to
get to fix this Charge 3 and gift it to someone. I have way too many
additional bands that I purchased for it that I wouldn't love seeing going
to waste, plus it still holds a charge for at least 5 days.
Best regards,
04-03-2020 20:28
04-03-2020 20:28
I believe the water caused it. I also wasn't too careful when washing my hands because it was supposedly waterproof, and it broke. Same symptoms. I can't fix mine either.
04-03-2020 21:53
04-03-2020 21:53
Yes I am having the same issue. I have tried to reset, and have changed the clock face multiple times. I have even chatted with someone only to be told I could get a 25% discount on a new Fitbit. This is already my second Charge 3 in a year. Please escalate so that someone else can try to fix this issue. I agree with others that there should be a way to restart/reboot on the app. Without the screen view it is difficult to tell if I am actually turning it off. I have read that others were able to have it restarted with a support agent, but I was told that they can't do that. Is there only way to restart? Please help
04-04-2020 00:18
04-04-2020 00:18
Without the benefit of the screen, the only way to restart is to wait for it to go off completely (when you touch the button, no buzz is heard) then charge it again.
Now that they have released Charge 4 (which is just a more revamped version of Charge 3) I am waiting to hear what the new users will experience because Fitbit rarely listens to customer feedback.
04-04-2020 04:23
04-04-2020 04:23
I am on my soon to be third. It just goes black. No reset is helping at all. It will vibrate from time to time but no face. So annoying I love my watch!!! It was going crazy two days before it died saying my heart rate was through the roof and than it just died . Nothing is working at all
04-04-2020 12:07 - last edited on 06-29-2020 10:14 by AlvaroFitbit
It wasn't water. It is crappy software and/or hardware.
Moderator Edit: Personal info removed
04-04-2020 12:15
04-04-2020 12:15
My screen is gray with lines. I did the soft reset and no change. When I have seen this in previous devices, the device is on the way to failure.
04-06-2020 06:27
04-06-2020 06:27
Using the restart method worked with my Charge 3, thank you
04-08-2020 10:18 - edited 04-15-2020 04:21
My Charge 3 screen froze in the messages about a month ago. Resetting the clock face fixed that. Two days after that happened, by screen glitched and half of the data that was supposed to be centered in the screen was halfway off the right side of the screen. After recharging the next time it needed it, the screen hasn't come back on. It still vibrates and reacts like it would if the screen showed anything, but nothing shows up on the screen. I've tried changing the clock face (it vibrates when it has 'successfully' changed the clock face), and I've tried many different things to try and restart it, including all of the methods I've found in various forum posts, but nothing has worked. I've let it run completely out of battery and left it off the charger for a couple days then recharged it and still nothing.
I've given up on this FitBit working normally again. And I'm not sure if I'll be inclined to drop much money on another tracker.. thankfully this one was earned from a fitness program through work...
Edit: I ended up contacting FitBit support. They sent me a new Charge 3 since I was within the warranty period for my original one, despite having got it third party. Hopefully this one doesn't die, but it was nice that it only took two days for it to arrive.
04-08-2020 10:48
04-08-2020 10:48
I'm in the same boat. My screen had garbled white lines before it went blank. It is unrecoverable ) :
04-08-2020 11:31
04-08-2020 11:31
