01-23-2019
06:16
13:05
01-23-2019
06:16
13:05
Fitbit Charge 3 display not working, why? It was at 95 % charge
01-17-2020 02:27
01-17-2020 02:27
My Charge 3 is also not working; no display even after reset and change of clock face. What other options do we have?
01-17-2020 03:41 - last edited on 09-06-2020 19:09 by LiliyaFitbit
You may need to contact https://contact.fitbit.com
I am just wondering - could this be a bug with Charge 3 and that they
probably know about it?
Best regards,
01-17-2020 09:44
01-17-2020 09:44
Support has cange my watch too😊
01-17-2020 12:59
01-17-2020 12:59
I have exactly same problem. Tried resetting it 100 times, changed clock face no help at all.
01-20-2020 03:58
01-20-2020 03:58
Ok. Blanks screen tried reset . Face change and worse of all... I disconnected Bluetooth and now can’t see screen code too renter for Bluetooth connection.
01-20-2020 16:29
01-20-2020 16:29
I am having the same issue, resetting and changing the clock face through the app has not fixed this. Has there been another option? I've only been using this for 5 months ago. I have had the charge 2 and the charge HR and used them for much longer than this one. I don't want to have to buy another already.
01-20-2020 16:49 - last edited on 09-06-2020 19:10 by LiliyaFitbit
Well I tried all suggestions to fix charge 3 display. 8 seconds on charger
then off and back on charge ...no result . many times. 15 seconds as well
no result ... tried changing display as well .. multiple times. Final
effort was to drop charge 3 off Bluetooth ... big mistake because to repair
to ones phone the app asks for the code displayed in the Fitbit.
Finally called support explained all and they are sending a new charge.
BLESS EM.
Thanks and Regards
01-22-2020 21:59
01-22-2020 21:59
01-23-2020 03:48 - last edited on 09-06-2020 19:10 by LiliyaFitbit
1 (855) 253-6120--
Thanks and Regards
01-23-2020 03:51
01-23-2020 03:51
I’m now waiting for my 4th one to be delivered, my last replacement lasted 3 weeks..🤬
01-23-2020 05:53
01-23-2020 05:53
01-23-2020 12:09
01-23-2020 12:09
01-23-2020 12:41
01-23-2020 12:41
In bright light, the display is completely unreadable. Adjusted settings from auto to normal, no help. Also, sync to iPhone using 13.3 is very slow and needs to be resynced over and again. Yes, i followed the 13.3 help guidelines.
02-03-2020 10:34
02-03-2020 10:34
Hello, the screen of my charge 3 stop working, I already try to press the botton 8 seconds several times trying to reset it and nothing happend, I plugged it to charge it and still the same. I bought it 2 months ago (december 2019).
02-13-2020 18:38
02-13-2020 18:38
I recently encountered the same problem with my screen where I have lines showing from bottom to top. I've owned my Fitbit just over a year....Disappointing given I've taken excellent care of it and there's no solution that's easily doable other than buying a new one. The problem of the screen and white lines seems to be so common, a recall should've been issued by Fitbit.
02-14-2020 06:34 - last edited on 09-06-2020 19:11 by LiliyaFitbit
Fitbit will replace. They replaced min.
Thanks and Regards
Sent from IPhone
02-14-2020 06:36
02-14-2020 06:36
02-14-2020 07:05
02-14-2020 07:05
02-15-2020 00:19 - last edited on 09-06-2020 19:11 by LiliyaFitbit
The same thing ultimately happened to mine. The display is simply
deteriorating gradually with those lines becoming more and more to an
extent that now I am barely able to see anything on portions of the screen..
Best regards,
02-15-2020 17:45
02-15-2020 17:45
Call multiple times i was told by a customer support rep that this is a known issue. They will tell you tough luck, if your warranty is out. Ask them to escalate this issue and hopefully the manager takes care of you. if not call again.
