10-09-2018
11:17
15:47
10-09-2018
11:17
15:47
I just received my tracker about an hour ago. I've turned it on and synced it and I've got a solid white line across the middle of the screen! Is there any way of fixing this or is it going to have to be sent back for replacement?
A reboot didn't help...
01-14-2019 17:18
01-14-2019 17:18
Just recived my brand new charge 3 in the mail today. I seem to have the same problem with the white line across the screen and a dead pixel. I tried resetting it multiple times. Also checked firmware but no update seems to be available for my device. I have tried all propsed solutions with no luck. How do I go about getting a replacement? Sad to see so many people having the same issues with their brand new devices.
01-15-2019 16:44
01-15-2019 16:44
I also have the horizontal white line across my screen. It started with it being the only display yesterday so when I got home I rebooted it. The charge 3 gave me the smiley face with the line through it and now it is permanently there. I have rebooted again and changed clock faces but the line is there and off putting to someone with poor eyesight. Please help.
01-16-2019 18:13
01-16-2019 18:13
Same problem here. Has a solution been found?
01-17-2019 03:46
01-17-2019 03:46
01-17-2019 06:43
01-17-2019 06:43
01-17-2019 07:27
01-17-2019 07:27
I cannot even get that much on the screen. Just a white line. I'm not sure how to restart/reboot it. How do you do that?
01-17-2019
08:30
08:13
01-17-2019
08:30
08:13
Hey everyone, I hope you are doing fine and thanks to all for troubleshooting this display issue by yourselves and @RiseAndShine for the input.
@Pattycake1. Regarding your inquiry, there isn't an option to delete your post. In the other hand, I am glad to hear that your display issue has been resolved. If there is anything else we can help you with, do not hesitate to post it.
@Alli327. Since the steps tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
@kcolbeez, @SunsetRunner and @SARAHREQ. Upon checking with our support team, I was told that you have already created cases with them. I know they will be glad to help you out and provide you a solution.
@Gran98. It's great to hear that you received a new tracker from Argos and that it is working properly. Let us know if there is anything else we can help you with.
@ofmgr421. Since you haven't tried to restart your Charge 3, I recommend following the instructions provide in the How do I restart my Fitbit device? help article to perform this.
Keep me posted.
01-19-2019 07:10
01-19-2019 07:10
Hello
i also have a white line across my screen.
Is is this a fault or something an update can resolve?
01-19-2019 08:21
01-19-2019 08:21
01-19-2019 13:39
01-19-2019 13:39
Hello @JenCo1965, it's good to see you around in the forums. I'm sorry to see you've experienced some trouble with your Charge 3 display.
Please check if the white line across the display is the one indicating the device needs a firmware update, as @Gran98 mentioned. However, if you continue to see this white line on the display, please try to perform a restart on your device and check if you continue to see the same on your display.
Keep me posted on the outcome.
01-19-2019 14:08
01-19-2019 14:08
Hi
i out it on charge and did a reboot while on charge.
All that happened was a smiley face and the line remains.
How is do I update the firmware?
01-22-2019 20:54
01-22-2019 20:54
I just bought the Charge 3 today. Same thing. White line horizontally across a blank screen. Please help.
01-30-2019 02:52
01-30-2019 02:52
I’m having the same problem. Have had it on one day and it’s got this line going across it. Any news on how to fix it?
01-31-2019 06:54
01-31-2019 06:54
This worked for me from support....
Thanks for getting back. We suggest you try to do a long restart for your Fitbit Charge 3. You can follow the steps here:
1. Connect the device to the charging cable.
2. While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
3. The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
4. The device turns off.
5. The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
6. Remove the device from the charging cable. The device shuts down.
7. Important: Plug the device into the charging cable again.
Let us know how it goes!
01-31-2019 06:55
01-31-2019 06:55
It wasn’t instant. The line came back then disappeared about 45 minutes after doing these steps.
01-31-2019 06:59
01-31-2019 06:59
02-01-2019 18:14
02-01-2019 18:14
I just bought my fitbit today, and I'm having this issue as well. Has a solution been found?
02-04-2019 06:57
02-04-2019 06:57
02-04-2019 09:36
02-04-2019 09:36
My Charge 3 has this line now too. Didn’t have it from the start, but has it now. Have looked for a way to “update the firmware” that some have suggested, but can’t seem to find anything like that. Line is annoying and I spent too much money on this thing to have a line through the middle of it.
02-04-2019 12:23
02-04-2019 12:23
Well, lol, the line went away! I guess I just had to tell on it! 🤷🏻:female_sign:
