11-27-2018
07:54
07:57
MarcoGFitbit
11-27-2018
07:54
07:57
MarcoGFitbit
When replying to text messages from Versa, messages are sent three times. Using Pixel 3 and Google Messages app. Anyone else with this problem?
04-11-2019 13:48
04-11-2019 13:48
Best Answer04-11-2019 14:14
04-11-2019 14:14
Sorry I couldnt help. Fitbit needs to come up with a fix for all supported phones. I have a pixel xl2 and this fix has held for me. I have all of the most recent android pie updates and maybe that fixes the issue. But so many people with the same problem that must be addressed. My wifes charge 3 has never had the problem nor have I read about the issue on the charge 3 so I expect its with the Versa software not the phones.
Best Answer04-11-2019 14:49
04-11-2019 14:49
Best Answer04-13-2019 16:30
04-13-2019 16:30
I have a Note 8....and when doing a quick reply it sends 4 or 5 of the same message. Is there a way to fix it?
Best Answer04-13-2019 16:31
04-13-2019 16:31
I have a Note 8....and when doing a quick reply for text messages... it sends 4 or 5 of the same message. Is there a way to fix it?
04-13-2019
17:31
18:27
LizzyFitbit
04-13-2019
17:31
18:27
LizzyFitbit
Ok...I think I figured it out.
I literally had to type back in the original quick replies.
Then I restarted my phone and the app. I tried to reply to my son's phone,
because I certainly didn't want to be bombarding people with 4 messages
each time, and it seems to be working.
I hope it stays that way.
I also found that when I use my bluetooth headphones, I can receive phone
calls and talk to people. And I can only call out when responding to a
call that I dismiss through notifications. I would like a way to be able
to do a quick dial to favorites through the phone. I hope they can set up
an app for that.
TEAM - *T*ogether *E*veryone *A*chieves *M*ore
*Always believe that something wonderful is about to happen!*
Moderator edit: removed personal information
Best Answer04-17-2019 19:14
04-17-2019 19:14
Best Answer04-18-2019 00:39
04-18-2019 00:39
Just got my Versa today and it is sending between 2 and 6 messages on quick reply. Tested using both WhatsApp and normal text messages.
Have tried all the rebooting and resetting tips suggested by other users.
Best Answer05-06-2019 18:16
05-06-2019 18:16
Just got Charge 3 Special Edition connected to my Pixel XL. I see that dozens and dozens of people have reported this multiple quick reply problem. WHEN IS THIS GOING TO GET FIXED? Isn't this kind of ridiculous? The feature is completely unusable.
Best Answer05-08-2019 08:20
05-08-2019 08:20
I agree with your statement. Pixel needs to come up with a fix for this issue that resolves the problem on all Android devices. Since I found a fix that works with my Pixel XL2, I have not had the problem now for a couple of months. We should not have to make efforts to find our own fix and if there is a work around that fixes the issue, it should be coming from Fitbit not another blogger. But if you haven't tried rebooting your device, forgetting the Versa from the Bluetooth connection on your phone and let the watch connect to the phone, not the phone to the watch, you might try this step. It worked for me and also solved my problem with syncing, Nevertheless, Fitbit should not advertise a feature that doesn't work with most devices.
Best Answer05-08-2019 08:43
05-08-2019 08:43
Best Answer12-08-2019 07:48
12-08-2019 07:48
How do I send a message to multiple friends? Thank you!
