04-26-2018
04:41
07:54
AlvaroFitbit
04-26-2018
04:41
07:54
AlvaroFitbit
Weather app has asked me to sync since last evening. Still not working after several sync-ings and a restart. Suggestions or still some bugs?
04-26-2018 07:51
04-26-2018 07:51
My weather app hasn't worked since 4/23, and still isn't working after other they released the statement "app issues have been resolved".
04-26-2018 08:32
04-26-2018 08:32
I had a similar problem. There is a fix, but you need to sync your watch via a WiFi network that doesn't require a login screen. I am traveling and work and hotel have login screens for their wifi, so I can't update till I get home. I hope this helps.
Best Answer04-26-2018 08:40
04-26-2018 08:40
I just added my location manually and it is now working.
04-26-2018 09:10
04-26-2018 09:10
Thanks all for the suggestions.
I have tried syncing in several different places (home, work, etc.) to no avail.
My weather app shows my city but otherwise is blank except for the message to sync the app.
Any other thoughts?
Hopefully Fitbit folks can clear this up.
05-03-2018
17:31
07:54
AlvaroFitbit
05-03-2018
17:31
07:54
AlvaroFitbit
Mine wasn’t working either. I just restarted my iPhone and tada... it’s working
05-06-2018 07:48 - edited 05-06-2018 07:54
Hi everyone! Welcome to the Fitbit Community! I hope you're all doing well! When syncing your weather app make sure you open in on your Versa and start a sync with your phone/computer, this will update the information. Additionally make sure you have the Keep widget alive option on on your tracker's settings so it can update the information.
@Khibby thank you for sharing what you did to fix this issue as it may help other members in the same situation.
Let me know how it goes!
06-24-2018 17:49
06-24-2018 17:49
did something change recently that caused weather app not working any more?
07-08-2018 09:31
07-08-2018 09:31
No matter what I do, weather app wont update. These devices are too expensive to not work properly.
07-20-2018 11:57
07-20-2018 11:57
No it doesn't. I've done what you said multiple times and I get nothing.
07-20-2018 13:28
07-20-2018 13:28
Have tried all these suggestions but nothing works. Weather app just keeps saying to sync the Fitbit mobile app to update.
08-08-2018 02:21
08-08-2018 02:21
I am having this problem as well and have done everything suggested. Weather is still not working. HELP!
08-08-2018 09:52
08-08-2018 09:52
Hello everyone. I had this issue too and what I noticed is that if you keep your Versa screen on it will sync your location (just tap it while the Versa and your phone are syncing). I would start by restarting the Versa itself by doing the following:
1.- Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
2.- Let go of the buttons.
3.- If your Fitbit watch doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
Additionally you can try refreshing the link between your phone and your Versa by going to the bluetooth settings area on your phone and removing all devices listed there. Restart your phone and then open the Fitbit app to start a sync.
Keep me posted!
08-08-2018 21:27
08-08-2018 21:27
Nope. Tried everything you suggested. Still doesn't work for me.
08-08-2018 22:12
08-08-2018 22:12
@tjdriver remove from versa and re-add the app. Then reconfigure.
08-09-2018 08:25
08-09-2018 08:25
How do I remove the app? There is no option to uninstall it.
Best Answer08-09-2018 21:26 - edited 08-09-2018 21:30
@tjdriver ugh! You're right. I feel silly now... 😐
ETA: Does your versa sync properly? Like steps etc? Are you able to receive notifications? Also, how do you have the weather app configured?
08-09-2018 22:47
08-09-2018 22:47
@Marrrmaduke no worries.
Everything else works fine. It's just this darn weather app. I've also tried to manually enter a city but that doesn't work either.
08-09-2018 23:01
08-09-2018 23:01
@tjdriver for me, only current location works and one preset location - Toronto. And then anyways the app loses Toronto. At least current location works... I hope they fix it...
08-09-2018 23:06
08-09-2018 23:06
@Marrrmaduke thanks for the help. I hope I'm able to get it fixed too. 😏
