07-24-2022
10:00
18:33
YojanaFitbit
07-24-2022
10:00
18:33
YojanaFitbit
My Versa stopped receiving notifications a few days ago. I've done a lot of troubleshooting and it still won't receive notifications. It's not even receiving the test call notification. It's still paired to my phone and syncing with the app but I'm not receiving notifications on my Versa. I don't know what else to do.
Best Answer08-13-2022 09:29
08-13-2022 09:29
@pam120800 -this was partially my mistake. The app ver is
The Firmware version is
If the app and firmware match- you should be good to test the shut down device, uninstall/reinstall app, set all permissions to allow, turn device on fix.
If it doesn't work tho, remember this is just a workaround for the moment as Fitbit has not fully fixed the issue.
07-25-2022 00:56
07-25-2022 03:46
07-25-2022 03:46
Mine hasn’t received notifications for 10 days, I’ve checked what you said above and it isn’t that, I’ve reset watch and reloaded app etc, think it must be a glitch !
07-25-2022 03:58
07-25-2022 03:58
@Bowgirl104 - just in case if you reinstalled the app did you fully setup notifications again ?
07-25-2022 04:06
07-25-2022 04:06
Just double checked again, will see if anything comes through when I get a message ! 😀
07-25-2022 04:57
07-25-2022 04:57
I noticed mine was doing something similar when I woke up Saturday... I'm able to get calls to my versa but no text messages. It's gone as far as booting itself off of my phone bluetooth and not reconnecting to it. I have no idea what's going on and I've tried everything. I'm glad it's not just me though.
07-25-2022 06:21
07-25-2022 06:21
I have and they are both disabled
07-25-2022 06:24
07-25-2022 06:24
It would appear there is a bug in the latest Fitbit App as it is occurring to so many people.
07-25-2022 22:25
07-25-2022 22:25
Mine is the same...stopped on Saturday, I've tried everything that is suggested on all the pages...nothing works!!
07-25-2022 22:32
07-25-2022 22:32
I raised this with the moderator as a possible bug in the latest Fitbit App.
07-26-2022 08:51 - edited 07-26-2022 08:54
Same issue since the update
Everything else works but messages and calls
Alexa also fine
Just zero notifications
07-26-2022 08:55
07-26-2022 08:55
Yea I don't see it on Bluetooth either now
07-26-2022 11:00
07-26-2022 11:00
Yes I have ,,,nothing I try corrects this.
07-26-2022 11:02
07-26-2022 11:02
Hopefully they will work fast lol to fix
07-26-2022 11:55
07-26-2022 11:55
Did a full factory reset nothing
Still not getting them or the phone call test
07-26-2022 11:58
07-27-2022 10:46
07-27-2022 10:46
Fitbit Versa 2
Platform: Android
App version: 3.64 (most up to date version per app)
Device: Pixel 4a5g
as of an hour ago, I stopped receiving notifications on my Fitbit versa 2. I have tried all of the basic troubleshooting steps suggested in other forums and help sites (disable BT for 10 sec. re-enable // un/re-pair device to Fitbit app // etc) none have worked to resolve this issue. Sleep mode and DND mode are off. Notifications are synced properly on the app.
Please assist.
07-27-2022 12:19
07-27-2022 13:19
07-27-2022 13:19
That's what I thought as well. But when I contacted support for assistance, they were not aware of any known issues w/ notifications and had me go through all of the troubleshooting steps again before escalating the issue to another tech. Apparently I'm supposed to get an email regarding the escalation within the next 24 hours?
07-27-2022
14:36
05:24
07-27-2022
14:36
05:24
Hi everyone. Nice to see that you're digging into the Fitbit Forums. Welcome to all new members!
Thank you all for sharing these details with us. I'm sorry the notifications aren't working well and to look into this, may I know the model and OS/software version of your phone? Do you recall since when this started to happening?
In the meantime and just in case you haven't done so, please give a try to the troubleshooting steps described in this help article.
I'd also recommend to give a try to the following:
Hope it helps.
