01-13-2016 21:29
01-13-2016 21:29
I just encountered one issue today. When i tried to turn on my Surge Bluetooth Classic, my device will automatically reboot. I tried it for 3 times and it keeps on rebooting the device. I shut down and start again but didn't help to resolve the problem. Anyone facing the same problem here? Help needed! Thanks.
Regards
Kelvin
08-20-2016 06:22
08-20-2016 06:22
Thanks for the update @dorst622. My advise is to contact back our support team and let them know you are still experiencing issues with syncing your Surge so they can continue with the assistance.
Let me know how it goes! ![]()
It is health that is real wealth and not pieces of silver and gold! Share your story!
09-24-2016 21:31
09-24-2016 21:31
@lkwkelvin , have you solved your problem yet? I have the same issue too, I strongly think its the App problem, once I updated the App on my tablet, my surge's bluetooth cannot switch off too, it restart / reset automaticly, I tried to remove my surge on my tablet, and relink it again, when I tried to switch off the App, my surge cannot switch off the bluetooth again, and now, I switch off the bluetooth when my tablet's fitbit App is still on, now my problem solved, my bluetooth can switch off now. Hope this can help.
Best Answer09-25-2016 19:22
09-25-2016 19:22
I end up buying a new pcs. seem to be related to hardware.
the first surge last about 10 months, i hope the second surger last longer.
if same issue happen, i am going to give up fitbit.
Best Answer10-01-2016 03:56
10-01-2016 03:56
10-13-2016 06:45
10-13-2016 06:45
Having the same problem, among many others.
Best Answer10-23-2016 16:16
10-23-2016 16:16
Best Answer11-04-2016 22:57
11-04-2016 22:57
Best Answer11-06-2016 22:00
11-06-2016 22:00
Best Answer11-06-2016 23:02
11-06-2016 23:02
Mine is the battery drianed.
It can run only a day.
11-17-2016 09:35
11-17-2016 09:35
It's great to see you around guys and welcome to the Forums @mengmac, @TuanLiew, @jmcpherson, @Apichai, @LeMoonBear ! ![]()
@mengmac Thank you for your suggestion and the participation in this tread. 😄
In case that you're still having issues with the Bluetooth Classic option in your Surge. Please restart your tracker a couple of times, update your Fitbit App to the latest version. Access to your Bluetooth settings to delete Fitbit from there. Reboot your Bluetooth once again and try to reconnect your Fitbit as a replacement device:
iOS: Account > Set up a device > Choose the option replace
Android: Main Menu > Devices > Tap on the (+) sign in the upper right corner > Replace your tracker
PC: Open Fitbit Connect > Set up a new device > Existing user > Replace tracker
If you're having syncing issues try the restart one more time and check this syncing steps.
Sync your tracker; this should be able to switch from Off to On or Pair. You can see this master post from @DerrickS to use the feature Music Control again.
Hope this works for you guys, let me know if you need more help. I'll around! ![]()
12-14-2016
17:56
11:10
YojanaFitbit
12-14-2016
17:56
11:10
YojanaFitbit
Thanks but it doesn't work.
Moderator edit: Format
Best Answer12-15-2016 18:03
12-15-2016 18:03
That's exactly what I've done when I faced this problem. But it seems like it doesn't resolve the problem and it links to more problems on the tracker such as the battery couldn't sustain more than a day. Need to charge it everyday. Thanks anyway for your information. 🙂
12-16-2016 04:13
12-16-2016 04:13
Hi,
I have this issue since November 2016 too. At first my Surge won't sync with my Iphone 6. I decided to delete my surge from my apps. Since then I could not pair with my phone anymore. The apps keep asking if my surge is not power on, seems like my phone could not detect my surge. At classic bluetooth only exist "on" and "pair', 'off' is missing. It happen when its exactly 1 year old, ie no more warranty....
12-16-2016 06:07
12-16-2016 06:07
Good morning @lkwkelvin and @Apichai! Thanks for getting back to me. If you've tried those tips already and it didn't help I'd suggest contact support directly so they can check what is happening with your Surge. ![]()
I appreciate the time your took to do all these steps, hope to see your around guys! ![]()
01-04-2017 15:08
01-04-2017 15:08
I had 2 surges and had problems with both: 1st one faced the Bluetooth/ restart issue, never solved. Got a replacement: 2nd one battery drained and it stopped working out of nothing... each didn't last 10 months... I gave up Fitbit and bought me a $200.00 Garmin, which so far is nice and reliable...
01-12-2017 19:08 - edited 01-12-2017 19:08
Hi All,
I am having the same issue and I have done everthing that is told on this forum. Still no success. I have written to the support team and waiting for their instruction.
Harsh
01-15-2017
23:22
08:04
YojanaFitbit
01-15-2017
23:22
08:04
YojanaFitbit
this methos is Work ![]()
Moderator edit: Format.
01-18-2017 08:11
01-18-2017 08:11
Hope you’re enjoying the forums @Harsh.madaan, @MiloS and @NaunG! Thank you very much for your feedback @MiloS, sorry for the inconvenience. Feel free to keep posting and sharing your thoughts!
@Harsh.madaan I think that's the next step too, hopefully they will be able to help you with this, please keep us posted on the resolution.
@NaunG That's great! If you have time, please check our Discussions board where you will find other members sharing their experiences and tips for an active lifestyle, you might be interested in this topics: Marathon Training or Plant-Based eating?
I'll be around! ![]()
01-22-2017 00:30
01-22-2017 00:30
