02-01-2018
15:45
14:53
02-01-2018
15:45
14:53
A while back I got a new modem and my Aria will not connect to it. I read through the troubleshooting on here, and made the necessary changes. My password is alphanumeric with no special characters and is set up as 802.11 b,g,n and STILL won’t connect. I haven’t had this scale for even a year and it’s a major hassle. Any other ideas on getting this to work? I’ve already had to get a replacement Charge 2 after 13 months and I’m really not wanting to spend money on the new Aria. It’s really awful that this is being sold knowing how difficult it is to connect to WiFi.
10-04-2018 13:20
10-04-2018 13:20
I know a lot has been written about this issue. Today, Oct 4, 2018, I talked with a Comcast tech support individual that said that the Xfi gateway cannot be reset to b/g/n without taking a significant hit to network performance. So if you are specifically using the Xfi system in your home, you have two choices: have the router reset to b/g/n mode and take a hit on overall performance of the network or get rid of or mothball your Aria scale until something changes. Personally, I have pulled the batteries for now and will give it another couple of months before I drop the scale off at our local electronics recycler.
I assume the need for the b level mode is hardware driven in the Aria and not a software/firmware issue (and I think it the same for the Aria 2 also). So there are no other choices at this time and neither is a pleasant option. Note this may not apply to other Comcast routers or levels of service, but it does appear to apply to the Xfi system that is in the upper tier of our local Comcast residential services.
10-06-2018 09:38
10-06-2018 09:38
@56rascal Thank you very much for your feedback and sharing these comments. I know that this has been frustrating.
10-28-2018 08:47
10-28-2018 08:47
Same problem here, Aria is such a PITA to connect to WiFi that it’s virtually unusable. They can’t seem to figure out what they’re doing in this company. HR wearables don’t last 2 months before the bands bubble and become useless too. They offered me a discount to buy their “new improved” version after the SECOND HR in less than a year bubbled and had to be thrown out! Why in the hell would anyone want another FITBIT product when the first three were all POSs?
10-31-2018 09:11
10-31-2018 09:11
@cuddlemutt I'm sorry about the experience you had with your Aria scale and I'm also sorry to hear that it's not covered by the warranty. I totally understand how you feel about this and your feedback is greatly appreciated since this helps us to keep improving.
10-31-2018 09:28 - last edited on 01-30-2020 12:57 by LiliyaFitbit
So what feedback are you looking for? I have a version 1 scale that makes a
great paperweight at the moment that I paid $129 for 3 years ago? My wife
bought a scale 10 years ago for $29.95 and it still works great. I would
suggest Fitbit consider when they have the tech ready to support 5GH wifi
networks they launch it and provide an introduction offer of trading your
Aria 1 or 2 in (dont make any difference in value either ) and make that
available to anyone who has a current Fitbit scale.
Just a suggestion,
11-03-2018 09:30
11-03-2018 09:30
@MoparElmo I definitely understand your frustration and thank you very much for your suggestion. We truly appreciate your comments and feedback.
11-11-2018 21:27
11-11-2018 21:27
I also was told by Comcast that I could take the action suggested by Fitbit but that doing so would make my other devices not work as well or perhaps not work at all. Not worth the risk. So goodbye Aria.
11-13-2018 03:28
11-13-2018 03:28
@SunsetRunner We’re aware of the issue,
01-08-2019 20:19
01-08-2019 20:19
I can't find Additional Settings to make the changes you suggested. Have the instructions changed or been updated?
01-12-2019 08:39
01-12-2019 08:39
@MurrayJ Thank you for joining us in this thread and our Fitbit Community! Regarding your inquiry, please contact your Internet service provider so they can guide you how to make changes to your router. Make sure that the router settings run the protocol 802.11b and bandwidth 2.4GHz.
After this, follow the setup process as described in this help article.
Let me know how it goes!
01-12-2019 09:38
01-12-2019 09:38
01-14-2019 12:43
01-14-2019 12:43
Fitbit----Is there anything you will do to help us out? Like others have mentioned, I now have a heavy paperweight that is unusable. Is the aria 2 on a newer protocol?
01-15-2019 13:38
01-15-2019 13:38
Has anyone given up and shelled out more money to buy the Aria 2? Does is actually connect?
It's been 8 months I've experienced this issue with no resolution! After the 'workaround b,g,n' connection dropped after a day, I've been manually recording the measurements in the Fitbit iOS app, but I had to replace the batteries and now cannot get it out of setup mode because it will not connect! I have to leave a battery out to turn the scale off, and reinstall and repeat this process every time I want to use it!
@JuanJoFitbit - Is there any discount Fitbit will provide to replace their un-updated scale with the Aria 2?
01-22-2019 06:05
01-22-2019 06:05
@MoparElmo @johnc_ @LMH425 I know how frustrating this is for you guys. Our team is aware of this issue. Once a solution is available, we'll make sure to post it in the Community.
I'm afraid that we don't have a trade program with the Aria 2.
I truly appreciate your feedback since this helps us to keep improving.
01-22-2019 06:20
01-22-2019 06:20
01-27-2019 12:39
01-27-2019 12:39
This does not work, at least on my xfinity router.
01-28-2019 03:28
01-28-2019 03:28
@johnc_ @98JHSDFKjh I'm sorry about the setup difficulties you've experienced with your Aria scales. I know that this is frustrating. However, our team is looking into this and once a solution is available, we'll make sure to post it here.
Thank you for your feedback!
01-29-2019
21:42
08:20
JuanJoFitbit
01-29-2019
21:42
08:20
JuanJoFitbit
I can imagine how frustrating this is for those using an Xfinity supplied modem and gateway/router.
A device that has hardware that supports only 802.11b cannot support newer standards by a software or firmware upgrade. It should be noted that the decision to stop supporting 802.11b is by Comcast/Xfinity and not Fitbit. The information Comcast is giving that enabling 802.11 b/g/n mode will take a massive performance hit is not completely accurate. Without getting into technical specifics, if Aria is the only device communicating on the b standard you will not notice any difference in speeds. Since the device transmits only tiny amounts of data and is completely off otherwise, it wouldn't matter if it was using b g or n. It would only make a difference if it was transmitting large amounts of data and continually on.
Further, most newer devices use the 802.11ac which is a vast improvement over b/g/n. These devices usually communicate on the much less crowded 5ghz band. So things like laptops, tablets, phones, TVs, media streamers, etc that use large amounts of data would not be affected by the Aria if using this band.
My suggested solution for ANYONE with an Xfinity gateway is to stop paying the outrageous monthly fee for their hardware that is inferior to what you can purchase. I recommend purchasing a modem at least as fast as your speed tier, but a faster modem could be handy if the speeds are later upgraded. Also it's preferrable to have a separate router than the all in one models, since it's more flexible for technology changes down the road.
Another option is to use a second (old) router and create a separate wifi network on a different channel in the 2.4ghz space.
If setting up a second network with another device did you adjust the second wireless device to disable the DHCP server, put it in access point (not gateway) mode, set a static IP in the same subnet and out of the DHCP range of your gateway, and set both wireless access points to fixed, separate non overlapping channels with different SSIDs?
There is no need to "downgrade internet" in any event.
Moderator edit: merged reply
01-30-2019 08:23
01-30-2019 08:23
@gschoen Thank you so much for sharing this information and input my friend. I'm pretty sure that this info will help other users.
I'll be around if you have any questions!
02-13-2019 13:19
02-13-2019 13:19
I'll be waiting. If there is no fix within one month, I will be replacing my Aria scale with one that is more modern.
