09-05-2024 11:06
09-05-2024 11:06
My app has stopped recognising any activity. Last weekend everything was working fine then 2 days later my tracker is showing calories burnt after a class but on syncing to the app…no exercise registers. I have done all the recommended stuff…opening/closing/deleting apps and tracker and still nothing.
Does anyone have any suggestions/ideas/advice please?
03-13-2025 18:55
03-13-2025 18:55
I have not seen anything in the Fitbit Community on if anyone has been having problems with the latest Fitbit Charge model.
03-14-2025 03:50
03-14-2025 03:50
@Rtkat3 I browse nearly all the forums regularly. This seem to be an issue with the Charge 2, not the Charge 6. The two models have very different operating systems. I haven't seen any posts about this issue with the Charge 3, 4, or 5, either.
Laurie | Maryland
03-19-2025 12:24
03-19-2025 12:24
I think the website mentioned that Charge 6 is the latest Fitbit Charge model.
03-19-2025 14:49
03-19-2025 14:49
Hi everybody! Thank you for your messages
@Rtkat3 , you are right, the latest Charge model is the Charge 6.
@all Our team has identify that this issue is being caused by the Fitbit app and not by any Fitbit device specifically!
They are working on a solution for this.
Hopefully we don't need to wait longer .
03-19-2025 14:53
03-19-2025 14:53
Thanks for the update @JuanFitbit. Keep us posted on when it is resolved.
03-21-2025 13:42
03-21-2025 13:42
I have both a Charge 2 and a Charge 6, and I have no problems with the Charge 6 not reporting logged workouts back to the app. Also, in the process of fixing … whatever it was they fixed, the Charge 2 can now report floors climbed in while letting the Charge 6 manage everything else. So I basically use the old Charge 2 only as an altimeter (which the. Charge 6 doesn’t have) and it seems to work (even if it does look sketchy AF to be running around with two Fitbits on my arm).
This could be an issue in the app, but it seems much more likely to be a fault in the tracker. The reason I can get away with having both of them report back what they know is they use two different interfaces. I forget what they call the one they introduced in the Charge 5(?) but it’s different and you can’t get 2 devices of the same type to cooperate this way.
Also, if I’m remembering right, this problem was present in the Charge 3 and early models of the Inspire trackers as well. (You know, the pre-Google models.)
03-21-2025 13:53
03-21-2025 13:53
The app issue is what @JuanFitbit said. At least your Charge 6 isn't having errors like any other models listed in the community discussion.
04-05-2025 17:51
04-05-2025 17:51
Any update on a fix yet?
04-05-2025 19:22
04-05-2025 19:22
04-07-2025 15:56
04-07-2025 15:56
Hi everybody ! Thank you for your messages.
I've verified with our team and they are still working on this.
They haven't provided any ETA yet.
But as always I suggest you all to have the latest Fitbit App installed. In case the fix is relesead before we get the chance to inform you all here.
We will update the thread as soon as we receive further info.
04-07-2025
15:59
13:40
AndreaFitbit
04-07-2025
15:59
13:40
AndreaFitbit
They said it was a problem with the app. Someone said that the Charge 6 was the latest Charge model and no one has reported any problems about it.
05-04-2025 19:20
05-04-2025 19:20
I just updated to the latest version. It still haven't been fixed.
Is there work in progress to get this fixed?
05-04-2025 19:35
05-04-2025 19:35
Try asking a moderator on this discussion and see if any of them can answer that question.
05-06-2025 13:03
05-06-2025 13:03
@Rtkat3 , Thank you for your help.
@storyseen @joggerj Thank you for your comments and updates.
Just to confirm and avoid further confusion as more than 1 topic in the discussion were mentioned, the issue that still appears to you is the one where the historical data is missing, right?
If so, please let us know your phone model and the operating system it uses. (eg. Pixel Phone 6 Android 12, iPhone 14 iOS 15, etc)
05-06-2025 13:27
05-06-2025 13:27
Mine is a Moto g power (2021).
06-03-2025 06:28
06-03-2025 06:28
Updated app to 4.43.1 and the problem still not fixed. Unable to track exercise from Charge 2. It does not show up on the app.
06-03-2025 09:49
06-03-2025 09:49
06-03-2025 11:36
06-03-2025 11:36
06-03-2025 11:41
06-03-2025 11:41
The glitch must be something so big that the support team is trying to do something about that. Any one of the moderators can help confirm this.
06-27-2025 08:28
06-27-2025 08:28
Seriously frustrated. My charge 4 fell apart so I've gone back to my 2. Not being able to sync my workouts is frustrating. It only recognizes the steps, and active minutes. yet if I don't hit workout it will recognize any activity over 20 minutes .
Time to start thinking about another brand. Will not be fitbit or Google devices
