10-30-2018
07:09
15:03
10-30-2018
07:09
15:03
My Charge 3 has stopped vibrating for all notifications. I've checked all settings on my Fitbit and phone and all is set correctly but still no vibration!!!
unhappy 😢
10-24-2020 22:57
10-24-2020 22:57
I received my Charge 3 March 14th, 2019. It has worked fine, but in about February of 2020 it suddenly stopped vibrating completely. I’ve tried to uninstall then reinstall the app, clear data, restart my Charge 3, and made sure all my settings were correct. Vibration is on, as well as being on Strong instead of Normal. Still no vibrations though.
10-25-2020
08:10
05:07
JuanJoFitbit
10-25-2020
08:10
05:07
JuanJoFitbit
I have done that twice... still not vibrating nor are texts coming thru.
I have restarted twice... restarted phone as well. Even tried a Force Stop on the app
Still vibration and notifications is not working
Moderator edit: merged reply
10-26-2020 09:02
10-26-2020 09:02
I know this post is old but wanted to stop by and say thank you as this worked for me! Also for anyone trying this make sure the “sleep” icon is also off! I turned sleep icon off and screen wake on and vibration works perfectly again now.
10-31-2020 15:11
10-31-2020 15:11
Hi I've been trying to see why my charge 3 isn't vibrating and I've tried the restart method and it hasn't worked.
11-07-2020 04:16
11-07-2020 04:16
It still doesn’t vibrate
11-07-2020 15:23
11-07-2020 15:23
I also have an Answer too!
Read the following steps
1: turn on your Fitbit
2: go to timers
3: go to countdown
4: turn on your countdown to 1 second
5: double tap your Fitbit when the timer has end and it should vibrate!!!
Enjoy 😊
11-18-2020 10:56
11-18-2020 10:56
My charge 3 has stopped vibrating and showing my texts. I have restarted until I saw the smiley face but still not working.
11-23-2020 15:54
11-23-2020 15:54
My Fitbit Charge 3 stopped vibrating too. I found on the Fitbit device settings that "Sleep Mode" had been turned on. Turned it off and I have my vibrations back.
12-23-2020
17:08
05:08
JuanJoFitbit
12-23-2020
17:08
05:08
JuanJoFitbit
I tried restarting, it did not work.
Same here, restarting did not fix the issue.
12-23-2020 17:11
12-23-2020 17:11
12-23-2020 17:51
12-23-2020 17:51
12-24-2020 05:49
12-24-2020 05:49
12-24-2020 07:13
12-24-2020 07:13
12-25-2020 08:26
12-25-2020 08:26
Hier al maanden hetzelfde probleem. Instellingen nagekeken en verschillende keren opnieuw opgestart, geen resultaat.
Fitbit helpdesk geeft steeds dezelfde antwoorden die niet werken. Vervelend probleem!
12-26-2020 09:53
12-26-2020 09:53
I've restarted several times. I checked the vibrate setting - when I switch it from Normal to Strong, it vibrates momentarily. But it never vibrates anymore at 10 minutes to the hour or when I get a phone call or text message.
I have tried all the different suggestions. So now what?
12-26-2020 10:26
12-26-2020 10:26
12-27-2020
08:12
05:05
JuanJoFitbit
12-27-2020
08:12
05:05
JuanJoFitbit
Hi, thanks, this works!!!
Very nice!!
Kind regards!!
Thanks, this worked!! Very glad!
Hier hetzelfde probleem, kreeg gisteren van ander forum lid deze tip, die werkte (@Jmneves99):
Ga naar de instellingen op de Charge 3 zelf, scrol omlaag naar de slaapmodus en druk op. Zorg ervoor dat beide items zijn ingesteld op Uit. Dit loste mijn probleem op.
12-27-2020 18:53 - last edited on 02-07-2021 10:39 by LiliyaFitbit
Sent from my iPad
12-31-2020 07:11
12-31-2020 07:11
My wife has had the same issue on her Charge 3 for months, and this thread and the "turn off sleep mode" was what solved the issue. Thanks for that excellent advice.
12-31-2020 07:27
12-31-2020 07:27
Great! Fitbit helpdesk doesn't give this solution.
I'm also glad with this solution!
