10-06-2018
11:56
15:47
10-06-2018
11:56
15:47
I've bought the Charge 3 & I'm trying to set the Pool Length for swimming, I've looked at the help topics & it says to click Advanced Settings & then Swim Settings but when I click Advanced Settings in the App I don't have the Swim Settings option. The help topics also says you Can access the Swim Settings from the Excercise Screen on the Fitbit but i din't know how to find this. Can anyone help please? Many thanks
Moderator Edit: Updated Subject for Clarity
11-13-2019 19:35 - last edited on 12-24-2020 15:11 by LiliyaFitbit
hi go into the device itself, go to exercise the select swimming....swipe screen up and pool lengths are there.....change to what you need
Moderator edit: format
Best Answer11-14-2019 02:12
11-14-2019 02:12
Best Answer11-14-2019 02:41
11-14-2019 02:41
Best Answer11-29-2019 16:22
11-29-2019 16:22
On your fitbit, tap the screen and scroll to the left. Click on exercise and scroll through until you see swim, scroll up on the screen - from here you can adjust the pool length.
Hope this helps.
11-30-2019 01:46
11-30-2019 01:46
Best Answer01-10-2020 03:21
01-10-2020 03:21
I am trying to set my Fitbit Charge3 but when you going to dashboard/exercise/swimming it will only let you put in the duration of time. How can you set it to lengths 25metre pool?
Best Answer01-10-2020 05:03
01-10-2020 05:03
Best Answer01-10-2020 10:38
01-10-2020 10:38
Best Answer03-05-2020 07:40
03-05-2020 07:40
Go onto your Fitbit watch. Swipe right and click exercise. Swipe across until you find Swim. Don’t click Swim but swipe up on that screen and there it will show your current pool length. Click on Pool Length and change it to the length of your pool. Hope this helps!!
Best Answer10-16-2020 16:23
10-16-2020 16:23
My Charge 3 only has a "Main Goal" heading. When I open it I am only offered "steps, distance, calories burned, active minutes, floors climbed." There is no option for swimming. I am frustrated. The reason I bought this was to track my swimming...and my laps. I have swam in two different pools, both 25 yards. My tracker tells me it is 28 yards. It counts my kicks as steps! I usually use "auto recognize". I tried to just select "swimming" but then it didn't count my heart rate.
Best Answer10-17-2020 02:10
10-17-2020 02:10
Best Answer04-28-2021 16:50
04-28-2021 16:50
I’m trying to change the pool length on my charge 3 too but seem to have lost ‘goals’! Any idea why this might be?
