12-21-2016
00:46
07:45
WilsonFitbit
12-21-2016
00:46
07:45
WilsonFitbit
Hi,
I have been struggling to find out what is going on with my fitbit. I recently got it and for the first couple of days it reminded me to move but just stopped reminding me for the past 2 days.
I spoke to the help desk and they suggested I reboot the fitbit and turn the more remind off, but still its not working.
Did anyone have the same problem and is there anyway to get it to work again?
Maybe its faulty and I need to return it to the store?
Thank you
Christine
Restarting several times can work. Not just once
I would also make sure under settings and the Unit name that reminders is turned back to on. Also make sure the days you want to be reminded are still checked.
If they are than get back in touch with support or if bought in a store I would go exchange it. it will be faster.
Wendy | CA | Moto G6 Android
I have been having the same problem with my Charge 2 over the last few days. I have turned the reminders off and on several times but it is still not working.
I am going to try turning them off and re-syncing my phone, then back on again to see if that works.
Best AnswerI updated my Charge 2 yesterday and they haven't worked since. I restarted my fitbit twice and made sure the hours and days I want it to remind me are checked. I feel like it was a bad update. Does anyone else have different suggestions?
If the Charge2 was just recently updated let's make sure notification setting on the Charge2 bus turned on..While looking at the clock hold the button in.. This setting also turns off the hourly step reminder. Also check the app settings again
This is what my setting is at. I'm not sure what you are referring to when you say 'Charge2 bus'. If i hold down the button on the Charge2 the notification are already set to on. I still get notifications of phone calls and texts but dont recieve the reminders like I used to. It's very frustrating I work at my desk all day and it's a nice reminder that I haven't gotten up in an hour.
Ok it is ten minutes to the hour, I'm 82 steps and yes I got no notification.. Just saying that it is more than your trackers @jcarpenter, @christine007, and @KNWA
Best AnswerI'm having the same issue. Mine worked fine for almost a month and has recently quick working. Not sure if it coincided with the last update or actually quit before then. I think it was with this last update though. I've restarted, on-off notifications / reminders, sync'd and resync'd and nothing.
Press the button on the side once until the time shows. Then press and hold the button again and the notifications will show and hold until it shows notifications are on. This change seems to have happened toe veryone after the update.
Best AnswerDid you get it working? I'm having the same issue. Sat having a cuddle with my daughter and missed my steps that hour. Would have had a stroll round the kitchen if it had buzzed.
Nope I've tried every suggestion in this feed and even called. They gave me the same things to try and still nothing worked. I haven't had reminders to move for months now and sadly it was one of the reason i upgraded my fitbit and now i feel like I've just wasted my money.
